  • 28
darkstar22
Smart TV, less smart DVD, V+ box......
I have a Samsung smart TV, connected wirelessly to my Virgin superhub to access its smart functions, and via HDMI to my V+ box.  I have now acquired a less-smart Sony Blu-Ray DVD player, connected via HDMI to the TV - less-smart in that it needs to connect to the Internet to access updates and its few smart functions; but it doesn't allow wireless connection - it needs an ethernet cable to connect to the Internet.
My question is:  what are my options for connecting this ethernet cable?  The V+ box has an ethernet socket; but looking online, this has in the past been disabled - is it still?  And if not, will just connecting the ethernet cable to this socket do the trick?  If this isn't an option - can I just run a long ethernet cable to the superhub and plug it into one of the three sockets I see near its base, and connect it that way?  (Still a learner on these matters.)
Helpful Answers
  • 10.33K
  • 920
  • 2.1K
Re: Smart TV, less smart DVD, V+ box......
V+ No.
Long Ethernet cable Yes.
Powerline adapters Yes.
Universal wifi adapter, e.g. Netgear WNCE2001 Yes
All Replies
  • 10.33K
  • 920
  • 2.1K
V+ No.
  • 28
darkstar22
Thanks for that - suspected the V+ answer was too simple (sigh).  Must get a long ethernet cable.
Not familiar with either of the other two solutions (techy education at a relatively early stage); but I'll have a Google.
