CragratRM
SamsungV+ HD Box problems
My Samsung V+ HD box seems to have frozen and the only thing it shows on the box is the word STOP. I have tried all the usual disconnecting,switching back on again,changed batteries in the remote,checked all the leads are connected etc. When I go to HDMI on my TV it says NO Signal. It's a spare TV in the bedroom and the main TV is working fine with the Virgin Box. Any ideas?
RMCragrat
Helpful Answers
  • 10.14K
  • 1K
  • 1.88K
Re: SamsungV+ HD Box problems
STOP stuck on the box usually means a failure. More than likley the box will need replacing. Time to think about a second TiVO if you were considering one. They are only £1 a month more than your second V+ under the latest pricing, & you will get a replacement box thats far newer than the refurb V+ you will get on a fault swap.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
All Replies
  • 10.14K
  • 1K
  • 1.88K
CragratRM
Thanks for the help. It's probably time for a change from Virgin. The Broadband they keep going on about is very slow in my area and my bills keep going up for very little reason.
