jhweseman
Resetting volume control on remote model 11
I replaced my old TV with an LG smart TV. I used to control the volume of the TV with the remote control model 11 of my Virgin TV box. I found a code for the LG TV, applied it and the TV went into engineering mode. Bummer. I found somewhere on a Virgin page the following:
We’ve found a compatibility issue between LG TVs and the Type 11 remote control that means programming the remote could put your LG TV into ‘engineering mode’, stopping you using your TV.
You can continue to use our remote with your V, V HD or V+ HD box, but you will need to use the remote that came with your LG TV to control the volume and standby functions on the TV.
Now I need to change the remote so that it controls the volume of the V Box, instead of the TV. I tried several codes like 0000 but when I now use the volume control buttons on the remote, I see on the TV a log text saying something like you can change the remote to control the volume of the TV.
Help!
Harry
Helpful Answers
  • 8.46K
  • 421
  • 999
jb66
Re: Resetting volume control on remote model 11
virgin remote 12 can control LG Volume with code, best asking for a replacment
All Replies
  • 8.46K
  • 421
  • 999
jb66
jhweseman
Thanks, I asked for a replacement, it arrived today and it works great!
