  • 10
flower2
Replacement tivo box
Hi,  my Tivo box started working only intermittently recently and when I phoned I was told the hard drive had 'gone' and the box needed replacing.   I've read quite a few posts on here and all the replies are that an engineer needed to visit to check the box over.  This isn't a complaint but I'm just wondering how they knew my box couldn't be fixed?
  • 13.7K
  • 561
  • 959
Re: Replacement tivo box
Hi flower2
I thought I'd step in to answer your question if that's ok? The box has a non replaceable hard drive, so if we're detecting any errors from our end then it's likely an engineer would need to come to take a look and potentially replace the box.
I hope this helps
Craig
