Babyg3317
Replacement remote
Hi guys. Does anyone know if I can get a replacement remote?
Gaynor
  • 8.72K
  • 1.17K
  • 3.53K
Re: Replacement remote
Assuming you are referring to a VM remote control that is not working and you have changed the batteries, then yes.  Just follow the instructions in the help pages: My remote control is not working correctly
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
