PeterReg
Replacement remote control Samsung v+
Hi, my Virgin V+ (HD Samsung) remote has stopped working, the volume and channel buttons no longer work despite replacing batteries. How can I order a replacement?
thanks
  • 8.72K
  • 1.18K
  • 3.53K
Re: Replacement remote control Samsung v+
http://community.virginmedia.com/t5/TV/Replacement-Remote-Control/td-p/1506736
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
