  • 30
  • 5
Vale46
Message 1 of 12
Replacement power adaptor
Just had to order a replacement power supply for my VHD box (bad dog).   Anyone know why I have to wait for an engineer to bring it and plug it in rather than VM just posting one?  No TV for a week now because of this.
Helpful Answers
  • 12.66K
  • 1.61K
  • 3.73K
Message 2 of 12
Re: Replacement power adaptor
It should have just been posted out, like replacement remotes are. That is unless the following maybe happened:  A) the agent you spoke to couldn't get just the power supply sent out, so they booked in a replacement for not just the power supply, but the STB as well. Or, B) the agent seen that your STB has signal issues and decided to book an engineer appointment which would deal with both problems.
Any opinions expressed by myself are entirely my own and do not represent Virgin Media in any way.
  • 12.66K
  • 1.61K
  • 3.73K
Message 4 of 12
Sounds it.
You can use the engineer appointment page to see check (daily) to see if an earlier appointment slot has become available: https://my.virginmedia.com/faults/view-appointments
  • 6.69K
  • 264
  • 486
Message 6 of 12
Hi Vale46,
Thanks for posting!
Sorry our team couldn't post a power supply out to you.
Let me know how the appointment goes and give me a shout if you need anything else.
All the best  Smiley Very Happy
Josh
  • 6.69K
  • 264
  • 486
Message 8 of 12
Hi Vale46,
I don't know why you weren't sent one. Typically if we know that it's just the power lead at fault, we post out a replacement.
It might be possible that the agent you spoke to just wanted to cover all bases, just in case.
Josh
  • 6.69K
  • 264
  • 486
Message 11 of 12
Hi Vale46,
Definitely a good call by our agent!
Give us a shout if you need anything else.
Josh
All Replies
  • 12.66K
  • 1.61K
  • 3.73K
Message 2 of 12
  • 30
  • 5
Vale46
Message 3 of 12
Thanks Shelke.   Probably the first one as the STB wasn't powered up when I called due to the lack of the power supply.  The guy did sound a bit confused and went away for some time during the call.  He asked me if I wanted him to activate the box and also what box I had expected to receive.  Odd questions really.
  • 12.66K
  • 1.61K
  • 3.73K
Message 4 of 12
Sounds it.
  • 30
  • 5
Vale46
Message 5 of 12
I work weekdays Shelke so the only appointment they could fit me in was Saturday.  Thanks for your help again.
  • 6.69K
  • 264
  • 486
Message 6 of 12
Hi Vale46,
Thanks for posting!
Josh
  • 30
  • 5
Vale46
Message 7 of 12
Thanks for the reply Josh.  Any particular reason why I couldn't just be sent a power adaptor?
Kind Regards
Vale46
  • 6.69K
  • 264
  • 486
Message 8 of 12
Hi Vale46,
Josh
  • 30
  • 5
Vale46
Message 9 of 12
OK.  Thanks again Josh.  He did sound a little confused.  Smiley Wink
  • 30
  • 5
Vale46
Message 10 of 12
It turned out that the guy from the call centre got it right.  The engineer replaced the power adaptor and it worked but the STB went off when he jiggled the lead.  The conection must have been damaged inside so he replaced the STB too.  Then he noticed the HDMI connector was bent at a 90 degree angle where it entered the TV.  He even replaced that too.  Good call VM and thank you.   Smiley Happy
