DavidGMacD
Message 1 of 7
Replacement V+ Box Picture either will not fit screen, or is distorted
We have just set up a new V+ Box and cannot get a picture to fit our tv screen, or if it does it is distorted - having tried all our tv's 'aspect' options.
There was no similar problem with the previous V+ Box this one has replaced; nor is there a similar problem with the picture received via an ordinary arial.
Very annoying!
Any suggestions for sorting this please?
David
Helpful Answers
  • 242
  • 15
  • 55
steelysteph
Superfast
Message 2 of 7
Re: Replacement V+ Box Picture either will not fit screen, or is distorted
What connection are you using (HDMI / Scart)?
Also, if you let us know the TV model we can try to help.
All Replies
  • 242
  • 15
  • 55
steelysteph
Superfast
Message 2 of 7
DavidGMacD
Message 3 of 7
It is a scart connection, and the tv model is a Panasonic 'Vierra' model TX-L32DT30B model
  • 8.8K
  • 600
  • 1.74K
Message 4 of 7
Why are you using a scart connection when that model of TV has an HDMI input?
Get an HDMI lead and use that instead
  • 242
  • 15
  • 55
steelysteph
Superfast
Message 5 of 7
It's likely to be a Scart issue. As dannylau says, use HDMI and let the V+ talk to your TV to get the best picture.
DavidGMacD
Message 6 of 7
Thank you.
No HDMI cable was included so am using the Scart until it comes.
We do route it through a VCR/DVD player at the moment so I wonder if that is affecting it [although no different than before]
Hopefully when the HDMI cable arrives it will be sorted.
DavidGMacD
Message 7 of 7
Thanks - will get an HDMI cable!
