AnnMcd1
Remote not working
My remote control has stopped working , I've replaced batteries but no luck is there anything else I can do to get it working ???
thank you
Ann
AnnMcd1
Re: Remote not working
Anyone got any advise , or do I need to contact customer services ??
AnnMcd1 wrote:
thank you
Ann
  • 8.72K
  • 595
  • 1.73K
You need to phone 150 select the tv faults option and let it run any tests it wishes, eventually a human will answer
  • 16
Dimbers
Which remote are you having trouble with? is it for a V+ box? There are 2 remotes that look pretty much the same, but the batteries are inserted differently, i would re check that you have put them in correctly. I know it sounds like im telling you to suck eggs but ive seen it many times with the V+ remote.
