Leanne4
Remote control
My remote isn't working full time and having to use buttons on box. Tried changing battery's bur this hasn't made any difference.
  • 7.24K
  • 810
  • 3.04K
Re: Remote control
http://community.virginmedia.com/t5/TV/Replacement-Remote-Control/td-p/1506736
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
