Susiesue1
Remote control not working
My remote control is not working..mainly the home/guide button and volume. The light doesnt light up at all .Have changed batteries, tried removing them and pressing every button but not working.
It is an old remote and can change channels on box but need a new remote as disabled.
Can you help me and send a new remote or change box and remote?
Thank you for your help
Sue
Helpful Answers
  • 7.23K
  • 809
  • 3.04K
Re: Remote control not working
Here's how to get one - can't be done thru' the Forum.
http://community.virginmedia.com/t5/TiVo/Replacement-TiVo-Remote-Controls/td-p/1506734
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
All Replies
  • 7.23K
  • 809
  • 3.04K
Superuser 2016/17
Susiesue1
Thanks for your reply. I don't have a TiVo box but will try to order one
Sue
  • 7.23K
  • 809
  • 3.04K
Same procedure for your V+ or VHD box. Just ask for the right one for your box.
Superuser 2016/17
