LP1705
Remote Control Volume
Have just bought a new TV. Everything works but the volume button on my virgin remote. Have tried all the codes that virgin list for a Polaroid TV but still won't work. Have contacted Virgin but customer services say that one of the codes should work or need to use TV remote to change volume. Anybody any ideas please.
  • 8.02K
  • 423
  • 1.3K
Re: Remote Control Volume
Have you tried using the search, where the remote iterates through all of the codes it has stored?
http://help.virginmedia.com/system/selfservice.controller?CONFIGURATION=1001&PARTITION_ID=1&secureFl...
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
