degsy70
Just joined
Remote Control - Toshiba
Hi, I've just had Virgin installed and I have a Toshiba television. The engineer said that I won't be able to change the volume on my TV using the Virgin remote control...anyone else have this problem??
  • 4.95K
  • 146
  • 282
Forum Team (Retired) BenD_H
Re: Remote Control - Toshiba
Hi Desgy70,
Thank you for coming in and posting your comment, welcome into the Community.
I've had a check here and if there is a facility to use the volume you can find this by following this flow on the TiVo remote control Smiley Happy
Hold down the 'Clear' and 'TV' together for 5 seconds or until the led flashes green. Now press on the keypad 0-9-9-9. Once done, keep pressing the 'Channel' down repeatedly until the TV turns off then stop.
Turn the TV back on and you should be able to operate the Volume function.
Keep in touch.
Ben
