  • 76
dx90
Message 1 of 7
Question about a second box instalation
If I have a second box installed in another room, is it totally independent of the 1st box or do they both share the exact same channels from the packages picked?
Thanks for any info with this.
  • 11.13K
  • 1.03K
  • 2.27K
Message 2 of 7
Re: Question about a second box instalation
A second box would have the same channels as the first box and be able to watch different channels at the same time.
In addition, if the two boxes are TiVos and/or V6s and are both connected to your home network, you can watch recordings from one box on the TV connected to the other box. This is called Multi-Room Streaming, MRS.
  • 76
dx90
Message 3 of 7
How much would a 2nd standard HD box cost per month please?
  • 17.67K
  • 1.65K
  • 3.08K
Message 4 of 7
The standard box is a TiVo 500GB box. This would be £14.99 for delivery and activation, and then £7.50 a month.
  • 76
dx90
Message 5 of 7
Do you still supply the standard HD non TIVo box like the one I have installed here?
  • 10.72K
  • 1.07K
  • 2.01K
Message 6 of 7
As Ben states, the 500Gb TiVO is the standard box now. The boxes using the older firmware platform are on a phased withdrawal as customers change their contracts. You may have the option to move your existing VHD upstairs & put the TiVO in downstairs. It depends what VM's accounting systems will allow being set up.
su1718.jpgCable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
  • 76
dx90
Message 7 of 7
OK, thanks for the reply.
