  • 8
bazzabugs
Program tivo remote for sony 55x8005c tv
Hi I have been try to setup the tivo remote control for my sony 55x8005c tv. I get the tv to turn off and when I turn it back on to try the volume and mute but nothing works. Does any one know of a code I could put in manually that would work.  Followed all the set up procedure but still not working.
  • 6.21K
  • 232
  • 355
Re: Program tivo remote for sony 55x8005c tv
Hello bazzabugs,
Thanks for posting in the community Smiley Happy
I have added a link here which will give you all the information you need regarding setting up your TiVo® remote to use the mute and volume functions including the codes for your television.
I hope this helps and please let us know how you get on.
Rose
