  • 15
mcd54
Message 1 of 7
Problems with replacement V+
Replacement V+ installed 12th October and worked well initially! However, it has started pixilating and the sound breaks up. If I get another replacement, I assume it will be luck if it will behave or not, since it will be a reconditioned box!
Should I be considering Tivo or not. Reading through these forums, it would seem that there`s mixed feelings regarding Tivo! Again, from the forums, I take it that a new Tivo 500GB would be installation free and a cost of £5 per month would apply.
Helpful Answers
  • 10.13K
  • 1K
  • 1.87K
Message 2 of 7
Re: Problems with replacement V+
Not quite. If it is a straight box swap, TiVO boxes are now available self-install for a £20 delivery charge. If you dont already have a TiVO, then this would also be a good time to phone Retentions (150 option 4 then 5) & renegotiate your package. TiVO's do add £5 to your rental if you are on a non-standard package. If you go for one of the new "Big" bundles, the TiVO charge is inclusive. It will mean accepting a contact lock in for 12 months on three services, but more than likely you will get a better deal than you currently have.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
All Replies
  • 10.13K
  • 1K
  • 1.87K
Message 2 of 7
  • 15
mcd54
Message 3 of 7
Thanks for reply! Will probably go down the Tivo route and will phone retentions tomorrow to find out best deal.
  • 15
mcd54
Message 4 of 7
Have decided to hang fire with Tivo at the moment and have booked an engineer for Tuesday to look at v+ box.
  • 7.31K
  • 304
  • 648
Moderator
Moderator
Message 5 of 7
Hi there mcd54,
I'm really sorry to hear that you've started to have some issues with the replacement V+ box, and apologies for the delay in getting to this message.
Please let us know how everything goes with the technician today.
Apologies again
Huw
  • 15
mcd54
Message 6 of 7
Engineer fitted another v+ box a short while ago. He spent a fair amount of time running checks on the faulty box and checked all the connections and cables and replaced a splitter cable. He also checked the green box in the street and the little grey box on our outside wall. Since our 2 other boxes are working fine, the engineer concluded that it wasn`t a signal problem but a problem with the box, which he then replaced! He then waited to see if the problem occurred again when switching between channels. Thankfully there were no problems.
10/10 for service!!
  • 13.73K
  • 562
  • 963
Message 7 of 7
Hey mcd54
Excellent news, thank you for taking the time to let us know about this, I really appreciate it!
If you need any assistance with your service in the future, you know where to find us!
Take care
craig
