keithgb
Problems getting freeview TV (dvb T2) on my Virgin Telly Pad
Trying to get freeview (dvb -T2) on my Virgin telly pad.
Bought a DVB-T2 Pad TV Tuner HD809 that plugs into the micro USB port and connected an aerial but the software recommended (and downloaded from play.com) I installed on the pad did not recognise the tuner.  The software was cidana dtv.
Any solutions?
Helpful Answers
  • 11.69K
  • 1.11K
  • 2.41K
Re: Problems getting freeview TV (dvb T2) on my Virgin Telly Pad
Support for telly tablet is by Exertis, not Virgin Media.
I’m not sure if this support covers third party hardware and software products.
Further info here:
http://www.virginmedia.com/shop/mobile/tellytablethelp.html
All Replies
  • 11.69K
  • 1.11K
  • 2.41K
Further info here:
keithgb
Thanks for your help.
I eventually found the answer by messing around.  I can now watch freeview in HD on my Virgin telly pad.
The answer is simple, connect the input device to either of the full size USB ports - ignore the Micro USB port.  The only messy bit is finding a conversion lead.  Good luck and thanks again for your help.
Regards  Keith Brookbanks
