CroydonGooner
Playback problems
After pausing TV or watching recorded programmes our picture pixellates and the recording goes into ultraslow mode, stopping at times and then jumping forward. I have tried resetting the Tivo box but to no avail. Any suggestions please.
  • 4.28K
  • 102
  • 1.14K
frank_gm
Community elder
Re: Playback problems
Does this happen for about a minute in a recorded/playback programme?  If you rewind the part that had the problem does it play correctly.
Is there a pattern, e.g. does it seem to happen around ten/fifteen minutes past the hour? Just trying to identify whether or not it is a specific, known, problem.
Nice to be able to post again, after their mistake (removed by the Censorship team).
¡No Pasarán!
  • 13.73K
  • 563
  • 964
Hi CroydonGooner
Welcome to the Community, I'm very sorry to learn about the troub;e you've experienced with your TV service.
We'd love to know more about the issue, if you could answer Frank's questions that would be great. I've also been able to locate your account to run some tests on the set top box from our end and we're detecting some errors with the hard drive.
As a result, I'd like to arrange for an engineer to come and take a closer look, if you're available?
I've sent you information regarding this in a private message, which you can view by clicking the envelope on the top right of this page.
Look forward to hearing from you
Craig
