  • 5
peacem
Panasonic TV connected to TiVo box flashes every few minutes
Panasonic TV flashing on/off every few minutes. This is happening constantly. It is connected to TiVo box. I have tried powering all equipment off/on and checking all cable connections
  • 240
  • 15
  • 55
steelysteph
Superfast
Re: Panasonic TV connected to TiVo box flashes every few minutes
Hi Peacem
What connection are you using - is it HDMI?  Also, what model Panasonic TV?
  • 5
peacem
Yes it's HDMI. The TV is model 40cx680, a 40" 4k model
  • 5.14K
  • 182
  • 313
Hello peacem,
Welcome to the community.
Does this happen when you bring the Home screen up or is it only while you're watching a channel and if you have a spare one have you tried to replace the HDMI lead?
Looking forward to hearing from you
Rose
  • 5
peacem
Rose,
It happens during normal watching of channels.
I have only recently switched TV's from a Sony Bravia to the Panasonic,
I had no issues with the Sony so assume the HDMI cable is ok.
However, if the cable is the next step I will buy another one.
Mike
  • 5.14K
  • 182
  • 313
Thanks for getting back to me Mike,
Okay what I'll like to do instead is send one of the team out to take a look at this for you so if you click on the purple envelope at the top right of the screen you will see a message waiting for you with further information.
Kind regards
Rose
