  • 6
bj1878
No optical digital audio output on sports channels
Does anyone know why there is no optical digital output from TiVo box or V+ boxes when watching sports channels. It's ok in other channels. How do I fix this problem?
  • 8.72K
  • 1.18K
  • 3.53K
Re: No optical digital audio output on sports channels
Which channels are you having this issue with?
Optical digital output works on my TiVo on all channels, and is in Dolby on the HD versions.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
  • 6
bj1878
All sky sports and BT sports channels on both TiVo and V+ boxes. There is no digital optical output when on these channels but there is on other "normal channels" like BBC/ ITV etc
  • 6
bj1878
Sorted - it was as the Dolby setting - needed to set it to Dolby with PCM
