Seabed
My volume control & mute buttons do not work
My volume control & mute buttons do not work, the virgin engineer was in yesterday to get us hooked up & started
  • 7.25K
  • 811
  • 3.05K
Re: My volume control & mute buttons do not work
You need to set that up. Guidance here
http://help.virginmedia.com/system/selfservice.controller?CONFIGURATION=1001&PARTITION_ID=1&secureFl...
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
