boohoo
Just joined
My v+ box is being replaced - will I get a TiVo? I pay nearly £100 per month as it is!
I've got a v+ box - a single box that doesn't record - internet and calls - can I get this reduced?
  • 10.13K
  • 1K
  • 1.87K
Re: My v+ box is being replaced - will I get a TiVo? I pay nearly £100 per month as it is!
Nope. Faultly V+ boxes are replaced by refurb V+ units (TiVO is an upgrade on the V+). However, you say that the box does not record, so unless you have a box with the recording facilities disabled (the V+ is a 3 tuner recording box), then you have a standard box. If you have a standard box, it will now be replaced with a VHD.
If you are out of contract, then pick up the phone and call Retentions (150 option 4 then 5). They will look through your existing package & see if anything better is available.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
