  • 7
el00oc
Message 1 of 10
Multiroom and power line adapters
Hi there
I was wondering. I just have a TiVo in the lounge by the hub at the moment and would like to be able to watch TV in another room.
To do this can I just have an Ethernet cable running out my power line adapter in the bedroom into the back of the box I choose? I.e HD box or TiVo.
Is that it? Just because I don't want wires running anywhere between the rooms for a new box.
Also, if i just get the HD box and not another TiVo, is there any way of watching the recorded shows from the TiVo in my lounge in the bedroom?
Thank you in advance!
  • 21.44K
  • 758
  • 3.07K
Message 2 of 10
Re: Multiroom and power line adapters
no if you have a second box it must be connected to the cable network.
  • 7
el00oc
Message 3 of 10
Thanks apcyberax
By 'connected to the cable network' what cable do I need coming into the bedroom?
  • 10.12K
  • 999
  • 1.87K
Message 4 of 10
All TV boxes need to be connected to Virgins network coax cable. Splitting/Extending the cable would be included as part of the Multiroom box install.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV+), Talk Unlim Telco, VIVID 100, Virgin PAYG Mobile
  • 7
el00oc
Message 5 of 10
Great thanks!!! Can it be any coax off amazon or is it a specific type of coax cable?
  • 10.12K
  • 999
  • 1.87K
Message 6 of 10
Cable is specially made for Virgin, but dont worry about that as its a manned install & the install engineer will install the cable to the new box, & adjust the signal levels.
  • 7
el00oc
Message 7 of 10
Thanks very much nodrogd
The only thing is...I'm redoing my bathroom and want to run coax under the floorboards now so I don't have wires all round the house. However I'm not planning on getting multiroom for a few months so will need to source the coax cable myself. Can I get any coax cable? Thanks!
  • 10.12K
  • 999
  • 1.87K
Message 8 of 10
As already said, its specialised cable that is not available over the counter. Satellite/Freeview coax is not up to the job as interference can leak back onto the network & cause all sorts of problems, not just with your installation but your neighbours. If you can arrange to lift the floorboards, an installer will happily lay cables where you want, by DIY-ing the job is not an option.
  • 10.12K
  • 999
  • 1.87K
Message 9 of 10
Just to mention. Installers can also route cables externally around a property (but not over roofs) to connect equipment.
  • 7
el00oc
Message 10 of 10
Brilliant! Thanks very much for your help and for taking the time to reply to me.
