kellymahoney1
Just joined
I need a new remote control replacement
I'm in need of a new remote control
  • 7.22K
  • 806
  • 3.03K
Re: I need a new remote control replacement
Then follow the guidance here:
http://community.virginmedia.com/t5/Virgin-TV/Replacement-Remote-Control/td-p/1506736
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
