  • 5
Cliff65
Message 1 of 5
I need 4m coax cable for connecting my VBox to the wall with connections.
I have recently brought a new TV and I now require a cable extension as mentioned above to fit the TV to the wall. Can I obtain 4m cable with connections from the Virgin media shop or can an engineer supply? Any suggestions please.
Helpful Answers
  • 1.27K
  • 94
  • 235
stevedh2
Knows their stuff
Message 2 of 5
Re: I need 4m coax cable for connecting my VBox to the wall with connections.
I think the official reply is you need to spend £99 for an engineer to come and do it and re balance your levels.
I assume you can't just leave your vbox where it is and get a longer HDMI cable?
  • 97
  • 14
  • 23
andyjstew
Up to speed
Message 4 of 5
Hi Cliff65,
You can do this yourself easily however Virgin take a frowned look upon it (if you tell them).
Here is links to the kit you need
1x RG6 Coax Cable
Coax F-Type Connectors
F-Plug 2 F-Plug Connectors
I recently used all this kit when renovating my home and got Virgin in to install the box where i wanted with these cables pre-run and the engineer was happy as larry as all he did was plug the cabling in to the boxes and away he went.
Any questions let me know :-)
All Replies
  • 1.27K
  • 94
  • 235
stevedh2
Knows their stuff
Message 2 of 5
  • 2.76K
  • 223
  • 842
Dave_cq
Trouble shooter
Message 3 of 5
Is this the type of cable you're looking for?
https://www.amazon.co.uk/WHITE-VIRGIN-MEDIA-BROADBAND-EXTENSION/dp/B007OWNACC/ref=sr_1_3?ie=UTF8&qid...
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 97
  • 14
  • 23
andyjstew
Up to speed
Message 4 of 5
Hi Cliff65,
1x RG6 Coax Cable
  • 5
Cliff65
Message 5 of 5
Hi Dave,
Yes, it is exactly what I need and I have ordered it to.
Thanks Dave.
Cliff
