  • 5
Lyndsey3009
Message 1 of 7
Help !!!!!!!!!!!!!! tuning in remote
Hi I got my new tivo deliverered today my problem is the remote for the old virgin box no longer works after we have installed the new box, also the TV remote no longer works either for the TV ie sound, but the new remote volume doesnt work on the new remote i have tried all the codes and dont know whst yo do, I have a swisstec TV. I have followed the instructions to programme the remote but can't even get it to switch the TV off, any help would be appreciated Ive just spent 3hrs trying to fix this 😔
  • 5.75K
  • 213
  • 339
Message 2 of 7
Re: Help !!!!!!!!!!!!!! tuning in remote
Hello Lyndsey3009,
Welcome to the community.
Because you have a new remote you will need to pair it with the television to use the mute and volume functions. I have added the instructions for this here so I hope this will be easier to follow.
Please let me know if you're still experiencing problems pairing your remote to your television.
Kind regards
Rose
  • 5
Lyndsey3009
Message 3 of 7
Hi, we have done this and it still doesn't work do you have any other suggestions please
  • 78
  • 9
  • 20
EightBall
Up to speed
Message 4 of 7
What make is your TV?
Also, does the 0999 code do anything at all? If you use that code, hold the channel up button and watch the standby LED on your TV does it flicker at all?
  • 5
Lyndsey3009
Message 5 of 7
It's a swisstec, yep done that aswell used all the codes on line nothing seems to work
  • 78
  • 9
  • 20
EightBall
Up to speed
Message 6 of 7
Programming the remote control can be tricky, so I know where you're coming from!
Swistech seems to have a lot of associated TV brands, cytronix was one that I found on the TiVo remote codes list. The code for that is 0746. Maybe try that?
  • 4.95K
  • 146
  • 282
Forum Team (Retired) BenD_H
Message 7 of 7
Hi Lyndsey3009,
Welcome back into the Community and thank you for your post. I would like to help and i can see that you have already had some help, how did you get on with the code from EightBall in the end?
Keep in touch and thank you for your time.
Ben
