saaqib786
Help me
Hi, I am considering buying a TiVo box but the Virgin media box where the cable comes from is in the other room and my ideal place for putting the TiVo box is in the other room there is already a ntl box in that room but is inactive so I was wondering what to do.
  • 8.64K
  • 584
  • 1.71K
Re: Help me
You have 2 options you can self install or you can choose engineer install, if you choose the latter the engineer will install the box anywhere you require
  • 10.33K
  • 920
  • 2.1K
Re: Help me
When you arrange to get the extra TiVo, you will have to request an engineer install, rather than a Quickstart install.
saaqib786
Re: Help me
Will it be free to get it done by the engineer
saaqib786
Re: Help me
I already have broadband and calls with them. I will be using it for the free view channels.
  • 10.33K
  • 920
  • 2.1K
Re: Help me
You will need to discuss both ongoing monthly charges and any installation charges when you speak to Virgin Media to arrange the addition of TV to your current services.
