Lhenry1
Help it's not working
No tv no internet said it would be fixed by 10:30 tried everything. Area 21 please can you help both boxes are down and do not know what to do tried calling only be told call back they are shut x
  • 21.87K
  • 808
  • 3.15K
Re: Help it's not working
if its an area fault there is not much you can do. Have you restarted the router and TV box? what lights are on the boxes when its restarted or what error do you see.
  • 8.94K
  • 1.22K
  • 3.63K
I suspect auto text kicked in here. For is read if. For ou read you. For rights read lights.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
  • 21.87K
  • 808
  • 3.15K
or i'm drunk Smiley Tongue
