iain151
Message 1 of 5
Does the virgin box only produce 2.1 sound ?
 Hi does the virgin tivo box only produce 2.1 sound ? I have a 5.1 sound system and three speakers don't work with it yet work with my dvd player, cheers , signed getting old and not so technically minded Iain
Helpful Answers
  • 2.94K
  • 377
  • 929
Message 2 of 5
Re: Does the virgin box only produce 2.1 sound ?
Hi Iain
the Tivo can output Dolby Digital surround sound via the HDMI cable, if the box is setup to do this (see instructions HERE) and the channel is broadcasting with surround sound which I think is only HD channels at present.
______________________
Scott
Disclaimer - I don't work for Virgin Media. I'm just another VM user trying to help out so my answers may be wrong :-) If you do like my answer please mark it as helpful as it may help others
  • 977
  • 84
  • 224
Tavis75
Well-informed
Message 5 of 5
iain151 wrote:
Thanks , I will give it a go. I'm only using a scart at the moment will try with an hdmi cable
SCART doesn't carry 5.1 sound, so that will be the problem!
All Replies
  • 2.94K
  • 377
  • 929
Message 2 of 5
Hi Iain
Scott
  • 1.32K
  • 46
  • 179
BinghamBloke
Knows their stuff
Message 3 of 5
It did work with the optical out until it was broken last year.
We have ben told it should be fixed later this year but nothing in writing from any VM source.
iain151
Message 4 of 5
  • 977
  • 84
  • 224
Tavis75
Well-informed
Message 5 of 5
