NORJOHN02
Can't get remote to control volume.
Just had this system installed, now can't get remote to control volume on TV after following all instructions. Any suggestions?
  • 15.82K
  • 1.3K
  • 3.18K
Re: Can't get remote to control volume.
hiya @NORJOHN02 what TV make/model do you have, and what TV box do you have? you could take a look at -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=3943&CURRENT_C... to see if this helps
