2520
Just joined
Can i order a remote control for tv on line.
Can i order a remote control on line. Attempting to do it on phone and its driving me crazy!!!
Helpful Answers
  • 7.25K
  • 811
  • 3.05K
Re: Can i order a remote control for tv on line.
Generally not
http://community.virginmedia.com/t5/TV/Replacement-Remote-Control/td-p/1506736
When calling go for TV fault. Avoids all those menus . You should get straight through.
You could try web chat. Use the "Contact Us" link at the bottom of any Forum page and follow through. It can be a bit busy. If so keep refreshing the page every few minutes till a slot comes up or wait for the "prompt" box and jump in.
No other facilities available.
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
All Replies
  • 7.25K
  • 811
  • 3.05K
Generally not
Superuser 2016/17
