Mcphersonscott2
30 second delay using remote on unit
Hi there,
Having a slight delay action using the remote control? Changed the batteries, switched unit off, reset unit all the things your told to try but still having a 30 second delay between channels? Any ideas would be appreciated
  • 13.68K
  • 561
  • 959
Re: 30 second delay using remote on unit
Hi Mcphersonscott2
Welcome to the Community, I'm very sorry to learn about the problem you're experiencing with your TV remote lately.
What set top box is this for? If you press the buttons on the front of the box are you still seeing the delay? If not, it could be an issue with the remote itself.
Look forward to hearing from you and getting this sorted.
Craig
Mcphersonscott2
Hi there,
The issue keeps coming back with a 30 delay. Tried three thumbs down and pressing the last channel key (bottom right of hanndset) worked fora short time then went back to the same way it's now becoming a pain in the A**
Cheers,
Any ideas how to sort this out?
  • 13.68K
  • 561
  • 959
Hi Mcpersonscott2
Sorry to hear about the continued problems with your TV service, what set top box are you having trouble with?
Also, If you press the buttons on the front of the box are you still seeing the delay? If not, it could be an issue with the remote itself.
We'll talk soon
Craig
