  • 17
freeby
help, advice or guidance
I have the Full House X/L
I have a Tivo downstairs - 1 upstairs and a V+Box
How much would it cost me to have a V6 dowstairs and a V6 to replace the Tivo upstairs, or would it make more sense to keep the Tivo and replace the V+Box?
Does the engineer use the white cables that are there now?
Am i still able to use the superhub 3 in modem mode?
Any help, advice or guidance would be appreciated
Cheers
  • 8.02K
  • 423
  • 1.3K
Re: help, advice or guidance
If you're on the 200Mbps package, then £49.95 twice, plus £14.95, with an additional £5/mth.
Tbh, you'd probably be better replacing both boxes for the consistent experience, though no reason you couldn't only replace the V+HD.
http://community.virginmedia.com/t5/Virgin-TV-V6/TiVo-V6-Pricing-Explained/td-p/3281148/jump-to/firs...
The coax will remain, yes
The V6 boxes also need to be connected to your router (not necessarily the SH3). Ideally this should be wired, but powerline, or wifi may suffice.
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
