georgej1
Settling in
Message 1 of 7
Volume problems with New V6 box
Hi all.
Just taken installation of our new v6 box replacing the old v+ box, great box and features but since the engineer has installed the new box the tv volume has changed drastically!
i run a soundbar through the tv and with the v+ box volume on channels was around 12-20, now to hear it i have to turn upto 80-100(full) on hd channels its even lower. This was not a problem before whats happened.
I dont know what to do without having to use an extra control for the soundbar and plug that straight into the v6 box.?
Please help
  • 8.02K
  • 423
  • 1.31K
Message 2 of 7
Re: Volume problems with New V6 box
How is the soundbar connected to the TV?
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
georgej1
Settling in
Message 3 of 7
via a audio lead - rca red and white from soundbar to phono jack into tv
  • 8.02K
  • 423
  • 1.31K
Message 4 of 7
How about the model of TV?
I expect that the TV isn't handling the sound signal correctly. I'd hope there should be a setting to control what the TV does with a 5.1 signal if it receives it.
TV: XL+SkySports V6
Loc: ME10
georgej1
Settling in
Message 5 of 7
tv is lg 32lh4000
it was fine with our old v+ box?
  • 8.02K
  • 423
  • 1.31K
Message 6 of 7
Try going into the Audio settings on the TV and enabling SRS TruSurround XT.
Any reason you're not using the optical audio out?
TV: XL+SkySports V6
Loc: ME10
georgej1
Settling in
Message 7 of 7
sorted... just got off the phone to virgin, i went into settings , audio settings, and switched from dolby digital to dolby digital to PCM. Volume back to normal. The soundbar or tv dont have optical out
thanks
