  • 9
backslah_loser
V6 volume function on remote not working as expected
If i keep my finger on the volume button to increase the volume (number), it will only move up by 1.
E.G, current volume is 12, i press and hold the up volume button, however the volume only moves up to 13, not continuously until i remove my finger from the volume button.
This is the same when decreasing the volume.
What is wrong with my remote and how to do i have a replacement sent out?
  • 25
  • 12
dowie
Re: V6 volume function on remote not working as expected
Hello,
Check the remote codes for your TV manufacturer its possible more than one will control the volume, another code may work and give you the required results as the TiVO remote only uses 4 commands and most tv remotes have many ie input, audio, settings etc...
Dowie
  • 9
backslah_loser
The issue still persists, a non V6 remote works as expected but the V6 remote does not.
@VirginMedia, can you confirm if this is expected behavior?
If not, i presume i will require a new remote.
  • 349
  • 16
  • 78
Dav1d
Fibre optic
I had this when my V6 was installed.
As said above, there is probably more than one code for your TV, and the auto code search has found the first one that works, but not properly.
I printed out all the codes for my make of TV, and tried them manually until I found the one that worked the volume as expected. There is more than likely nothing wrong with the remote.
