jg72
Message 1 of 7
V6 remote locator function doesn't work
Just had the new V6 installed, can't get the remote locator (where it beeps) function to work.  The bloke who came to install it was a trainee and didn't know how to fix it!
  • 1.36K
  • 51
  • 194
BinghamBloke
Knows their stuff
Message 2 of 7
Re: V6 remote locator function doesn't work
You need to pair the remote to the V6.
Press and hold the Info button for 7 seconds and the red light at the top of the remote should flash green twice when it has paired.
I had to do the same thing yesterday after trying to use the find the remote option on Sunday and it not working.
  • 580
  • 50
  • 135
Corinneangela
Rising star
Message 3 of 7
Did you pair the remote?
jg72
Message 4 of 7
yep, have paired it but when I press the + button on the front of the box nothing happens, there's no beep.
  • 2.33K
  • 34
  • 204
jhuk
Super solver
Message 5 of 7
Go into Tivo settings and do it from there, I had to do same but the range is still as poor as IR but at least they now bleep so I assume on Bluetooth not IR.
  • 107
  • 18
Strangeland16
Up to speed
Message 6 of 7
You need to keep your finger on the up button on the v6 not just press it
  • 7
Andy766702
Message 7 of 7
I had to hold the button for about 20 seconds before it worked
