  • 21
Michaeljf
Message 1 of 10
V6 low sound
Hello, can anyone help? I have the new virginmedia v6 TiVo and have to turn my Samsung curve TV from normal sound 10 hearing to 24+ to hear anything !
When I use the TV without V6 the sound is perfect on 10, it's also perfect when playing blu rays.....
Helpful Answers
  • 8.02K
  • 423
  • 1.3K
Message 4 of 10
Re: V6 low sound
Is the V6 set to output Dolby or PCM sound?
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
  • 8.02K
  • 423
  • 1.3K
Message 8 of 10
Re: V6 low sound
BBC1 101, is a non-HD (SD) channel
BBC1 HD 108, is as the name suggests.
The latter can broadcast 5.1 surround sound, and I was wondering if that may be the cause - that your TV isn't properly converting surround to the two channels it supports.
TV: XL+SkySports V6
Loc: ME10
  • 8.02K
  • 423
  • 1.3K
Message 10 of 10
Re: V6 low sound
Excellent! Smiley Very Happy
TV: XL+SkySports V6
Loc: ME10
All Replies
  • 8.02K
  • 423
  • 1.3K
Message 2 of 10
Re: V6 low sound
Any particular channels, or all of them?
Are you listening through TV speakers, or an amp?
TV: XL+SkySports V6
Loc: ME10
  • 21
Michaeljf
Message 3 of 10
Re: V6 low sound
Hello, all channels and using TV speakers ! When I turn it onto normal TV 12 is loud and yet on V6 very low
  • 8.02K
  • 423
  • 1.3K
Message 4 of 10
Re: V6 low sound
TV: XL+SkySports V6
Loc: ME10
  • 21
Michaeljf
Message 5 of 10
Re: V6 low sound
Hello it was set to dolby and then I changed it to PCM but neither made a difference
  • 8.02K
  • 423
  • 1.3K
Message 6 of 10
Re: V6 low sound
Sounds as if the V6 has the volume set rather lower than the other imputs.
It definitely doesn't make any difference on an SD channel?
TV: XL+SkySports V6
Loc: ME10
  • 21
Michaeljf
Message 7 of 10
Re: V6 low sound
SD means ? Sorry not technically minded when it comes to this
  • 8.02K
  • 423
  • 1.3K
Message 8 of 10
Re: V6 low sound
TV: XL+SkySports V6
Loc: ME10
  • 21
Michaeljf
Message 9 of 10
Re: V6 low sound
Thank you so much a complete stranger willing to help, I changed the TV sound settings as you suggested! It worked 😀
  • 8.02K
  • 423
  • 1.3K
Message 10 of 10
Re: V6 low sound
TV: XL+SkySports V6
Loc: ME10
