  • 227
  • 42
fergiet
Superfast
Message 1 of 5
V6 and Logitech Harmony Hub/Remote
Can anyone confirm that the V6 box works ok with a Logitech Harmony Hub/Remote ?
Box is coming in a couple of weeks.
Thanks in advance.
  • 52
  • 5
bobblejones
Message 2 of 5
Re: V6 and Logitech Harmony Hub/Remote
Mine works fine
  • 8.63K
  • 584
  • 1.71K
Message 3 of 5
And mine, didn't even have to change any settings
  • 185
  • 15
phil-ntl
Superfast
Message 4 of 5
Works fine.
If you have an existing Tivo and Harmony, it uses the exact same commands so will work straight away. If not. just set the harmony up as VM Tivo. The V6 hasn't been added to the Harmony database yet (or hadn't when i last looked)
Cheers
Phil
  • 838
  • 45
  • 150
Well-informed
Message 5 of 5
My Harmony also works fine. The installer of the V6 was very impressed with the Harmony and said he wished VM gave them as standard with the V6.
There are 10 types of people: those who understand binary and those who don't
