  • 1.83K
  • 28
  • 211
deans6571
Super solver
Message 1 of 17
V6 Vs TiVo - SAME OLD USELESS PROBLEMS.....
Just want to say that I will NEVER. EVER. Use my garbage of a box, which VM keep touting as their most "Smallest, Fastest, Smartest" box to stream ANYTHING, EVER AGAIN........
Tonight, for the second time this month, I put on a show on Netflix for my kids to watch (A Series of Unfortunate Events - the new season) but yes, JUST AS MY OLD TIVO USED TO DO, Netflix throws up a message, about 20 minutes in, to say that the box is not connected to the internet. It's a joke - THE BOX IS CONNECTED TO MY HUB 3 VIA POWERLINE ADAPTORS FOR **** SAKE. 🙄🙄🙄🙄🙄😡
And the best part of all this - MY APPLE TV, WHICH ONLY CONNECTS VIA WIFI TO THE SAME HUB, can stream THE SAME SHOW 100% ISSUE FREE......
I will NEVER use my V6 to stream ANYTHING - ITS BLOODY USELESS🙄🙄😡😡 💩 💩💩💩
__________________________________________________________
Twitter : @deans6571 / Xbox Live : Deans F
Helpful Answers
  • 15.53K
  • 642
  • 1.04K
Message 9 of 17
Re: V6 Vs TiVo - SAME OLD USELESS PROBLEMS.....
Hi Deans6571
I'm really sorry to lean about the problems you're experiencing with your TV service recently.
I've located your account and run some tests on the set top box from our end for you, we're detecting some minor errors and I'd like to arrange for a member of the team to come and take a closer look, if you're available?
I've sent you information regarding this in a private message, which you can view by clicking the envelope on the top right of this page.
We'll talk soon
Craig
All Replies
  • 137
  • 19
gordy66
Up to speed
Message 2 of 17
Can you not try it with a cable just to see how it performs.
  • 13.41K
  • 595
  • 1.66K
gary_dexter
Message 3 of 17
So the V6 connects via PowerLine and the Apple TV via wifi.
Have you checked the PowerLine isn't at fault here?
  • 1.83K
  • 28
  • 211
deans6571
Super solver
Message 4 of 17
...trust me, it's not at fault - I used to use the very same PowerLine Adaptors to connect my Xbox One to my Superhub 1 (before upgrading to the Hub 3) - and even that, was always able to stream stuff, 100% hassle free.
It's the V6 which is at fault - Netflix loads, I load the show, it starts, then about 20 mins to half hour in, it crashes to a  black screen showing a message saying something like "Make sure you are connected to the internet, yadda yadda yadda....".
Weirdly, when I saw this screen I just pressed the 'Home' button on my remote, and it then did indeed take me back to the 'Home' menu of the V6, however, the tiles along the top of the Home screen, were all blank - like it had temporarily lost connection to the internet. I left it for about a minute on this screen, and the tiles slowly loaded back up. If I had then re-loaded Netflix, it would have then allowed me to continue with the show (this is what happened the first time Netflix gave me this error, but yesterday, I just chose to watch the remainder of the show via Netflix on my Apple TV).
It can't be down to a high utilization in my area (which I just thought of just now) as it would then also affect my Apple TV. If my Apple TV and Xbox One stream 100& flawlessly (which they do), I can only put it down the hardware - i.e. the V6.......................Smiley Indifferent
  • 1.83K
  • 28
  • 211
deans6571
Super solver
Message 5 of 17
.....I don't really have a long enough cable to try as my Hub (Hub is in the most central location of the house, so the wifi can reach everywhere) and V6 are at opposite ends of the room.
  • 16
CRonfire16
Message 6 of 17
I have 3 V6 and have no issues, 2 set up wirelessly and 1 Ethernet.
im on 300mb and never drop below 230ish
Try booking a tech out to test your signals etc?
TiVo was slow but V6 is so fast and since getting it hasn't dropped out once
Once you replace negative thoughts with positive ones, you'll start having positive results.
  • 1.83K
  • 28
  • 211
deans6571
Super solver
Message 7 of 17
...can a forum Mod please contact me then, to arrange a Tech to check signals???
  • 122
  • 67
tonyworks
Up to speed
Message 8 of 17
Just don't use it. Go down to their lowest package (for the internet) and use other devices for on demand services like the nowtv box or your smart tv. I have found it better and cheaper to do just that. I am now paying a very very low price to virgin just for a Tivo, phone and internet and I use my now tv box for everything else. Even with my monthly subscriptions to  nowtv I have found it faster, better and cheaper. And I am in control of it all!!
Tony
  • 15.53K
  • 642
  • 1.04K
Message 9 of 17
Hi Deans6571
We'll talk soon
Craig
  • 1.83K
  • 28
  • 211
deans6571
Super solver
Message 10 of 17
Craig_D wrote:
Hi Deans6571
We'll talk soon
Craig
Hi Craig - PM sent.
Just to add some further info - since my original post above, I have since switched the connection of my V6, to WiFi and it has been working fine since then, Netflix continues to work as does the V6 other streaming functions (perhaps my house wiring had something to do with the PowerLines not working 100% effectively)..
Are you able to clarify what exactly, are these "errors" you are seeing from your end, as I really don't want an engineer messing with my set up if its all working correctly (which it is from my end)?
