pete_dl
Message 1 of 13
V6 Power consumption
I'm interested to know how green this box is. Would someone mind measuring the standby power consumption and also switched on, watching one channel ?
                 Peter.
Helpful Answers
  • 108
  • 5
fiesata
Dialled in
Message 3 of 13
Re: V6 Power consumption
I Googled this and couldn't find an answer so used my plug in power meter to test it myself
I found that on standby the V6 used 11 watts and when recording or you are watching TV used 18-20 watts
So on standby would use approx 96Kw hours and being used 24 hours a day would use approx 175 Kw hours per year
Therefore on average we can assume around 136 Kw hours for the average user at say 15p-20p per Kw hour would cost £20 to £27 a year to run which is pretty good
Full marks to VM on providing  a vast improvement to the Samsung TIVO box I had before
All Replies
  • 17.85K
  • 1.68K
  • 3.13K
Message 2 of 13
Some details about it's power consumption here http://store.virginmedia.com/content/dam/eSales/corporate/VirginTVV6boxfactsheet.pdf
Power consumption/Power saving features
• Low Network Availability (LoNA) device - complies with Commission Regulation (EU) No 1275/2008 (as amended by Regulation (EC) No 801/2013)
  • 108
  • 5
fiesata
Dialled in
Message 3 of 13
  • 20.91K
  • 563
  • 3.3K
Sephiroth
Message 4 of 13
                 Peter.
No personal disrespect intended, but ....
We are in the 21str century and electricity usage is going to shoot up.  It's not the Tivo that needs to be green, just the means of producing electricity.  It's not as if these small household devices need to be fitted with a 3KW heating element.
And another thing, the EU has plans to ban high power kettles for "green" reasons.   Don't those idiots realise that the lower power will have to be applied for longer to boil the water and the same number of KW hours will be used?
  • 1.13K
  • 96
  • 280
vircom
Knows their stuff
Message 5 of 13
Soon to be followed by slow running taps to save water.
  • 11.71K
  • 1.11K
  • 2.42K
Message 6 of 13
@Sephiroth
The EU directive for the kettles requires that they initially reduce the pressure in the kettle to half an atmosphere so that the water boils at a lower temperature, thus saving electricity.
  • 8.89K
  • 612
  • 1.76K
Message 7 of 13
Ernie_C wrote:
@Sephiroth
If they make the inside of a kettle a vacuum it will boil without electricity
  • 20.91K
  • 563
  • 3.3K
Sephiroth
Message 8 of 13
Ernie_C wrote:
@Sephiroth
Even were that to be the case, it's twice as stupid. Because when you pour the water into the teapot, it will not be as hot as is required to make the brew.
So - you were joking, Ernie. No?
  • 11.71K
  • 1.11K
  • 2.42K
Message 9 of 13
Yes, I was joking. I no longer read EU directives now we're leaving.
We all know that the correct action to be green with any kettle is to only boil water you use.
  • 22.41K
  • 865
  • 3.27K
Message 10 of 13
do get a tasimo like me and only drink from that. Pods are wasteful but the EU doesn't care about that its not in the targets Smiley Tongue
