  • 28
scouse2
Message 1 of 7
V6 Box and HUB
Do you need a new hub with the V6 box ??
  • 10.68K
  • 971
  • 2.18K
Message 2 of 7
Re: V6 Box and HUB
As you already have a hub suitable for 100Mb or greater, no.
  • 28
scouse2
Message 3 of 7
Re: V6 Box and HUB
Well virgin media are sending me on with the V6 BOX
  • 4.36K
  • 105
  • 1.18K
frank_gm
Community elder
Message 4 of 7
Re: V6 Box and HUB
When you say "sending", do you mean it is a self-install?
Nice to be able to post again, after their mistake (removed by the Censorship team).
¡No Pasarán!
  • 10.68K
  • 971
  • 2.18K
Message 5 of 7
Re: V6 Box and HUB
What hub do you currently have and did you ask for a Hub 3.0?
  • 28
scouse2
Message 6 of 7
Re: V6 Box and HUB
no not a self install as it will be supplied with the V6 box
  • 28
scouse2
Message 7 of 7
Re: V6 Box and HUB
No not a self install and I have a HUB 3  and 100 megs
