kapaone
V6 Box Problem
Have 3 V6 boxes but one has the basic package ie no movies or sports but the others all have the full package. Why is this when I pay for full package. On Demand on this box also want me to upgrade package or subscribe to watch things
  • 9.13K
  • 1.25K
  • 3.72K
Re: V6 Box Problem
Does the problem box have a working connection to your VM broadband hub?
If it does then you will need to call it in as a fault. If not then you need to sort out the network connection.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
  • 568
  • 49
  • 134
Corinneangela
Rising star
Re: V6 Box Problem
On the 2 boxes not working properly, if you go to settings>network> connect to virgin media service now let it do it's stuff then see if you get everything?
  • 22.08K
  • 832
  • 1.63K
Re: V6 Box Problem
Hi kapaone,
Thanks fro your post and welcome to the forums. It's great having you on board with us.
When you choose to have multi-room, your subscription is for all boxes on your account.
As one of the boxes isn't getting the full package, it's likely it hasn't been activated correctly or synced up. I have sent some hits down to the boxes to refresh things. If you can reboot the boxes by turning them off at the power, leaving off for a few minutes and then turning back on. This should help resolve things.
Come back and let me know if you are still having an issue.
Kath_F
