  • 51
ashpole
Message 1 of 5
TiVo V6 with Infrared Remote ie Harmony Remote
I see the new V6 box has an RF remote, but will it work with infrared remotes? I'm not asking about whether any this or that remote has a V6 configuration - I'm just interested in knowing if the box has an IR receiver?
Helpful Answers
  • 8.8K
  • 600
  • 1.74K
Message 2 of 5
Re: TiVo V6 with Infrared Remote ie Harmony Remote
it does and it works perfectly with my harmony remote and I have made no changes to the programming since swapping over, though the one issued is blue tooth not RF
All Replies
  • 8.8K
  • 600
  • 1.74K
Message 2 of 5
  • 51
ashpole
Message 3 of 5
Cheers, thanks for that feedback.
Sparks_1_
Message 4 of 5
I have a Harmony Elite. What settings did you use on your remote?
Mine wont work if I put the model as TiVo?
TechMad
Message 5 of 5
I have just upgraded to a Harmony Hub from a One and I cant get it to turn on the the V6 Box any ideas what setting name etc as I had to skip it when doing the setup
