PeteCC
Message 1 of 7
TiVo V6 Box Front Display Panel
I had a V6 Box installed a few weeks ago and have just realized that the display panel on the front of the box (next to power on indicator) does not illuminate. All the ads show this with a glowing red virgin logo. My old Tivo box used to show red lights for each programme that was currently recording, this box shows absolutely nothing other than the power on/off light.
Is this normal??
Helpful Answers
  • 17.66K
  • 1.65K
  • 3.08K
Message 2 of 7
Re: TiVo V6 Box Front Display Panel
Yes it's normal. You should only see the Power light unless something is wrong.
I think the advert itself was using TV magic to enhance the printed Virgin Media logo on the front for branding identification.
  • 11.12K
  • 1.03K
  • 2.26K
Message 3 of 7
Absolutely normal - big white LED in operation and big red LED when in standby.
All Replies
  • 17.66K
  • 1.65K
  • 3.08K
Message 2 of 7
  • 11.12K
  • 1.03K
  • 2.26K
Message 3 of 7
PeteCC
Message 4 of 7
Thanks - mind you I can see a WiFi symbol together with thumbs up/down embedded within the screen
PeteCC
Message 5 of 7
Thanks - althoughI can see a WiFi symbol together with thumbs up/down embedded within the screen
carpo72
Just joined
Message 6 of 7
I have these symbols too.
Did you find out or solve their meaning. Thanks
  • 4.46K
  • 110
  • 1.24K
frank_gm
Community elder
Message 7 of 7
I can easily see the red virgin logo from the other side of the room and had thought it was illuminated until I was corrected on the forum.
I also see a dull yellow light flashing when there is a problem with the network. In my case it usually shows when I am switching between a wired and wireless connection. It illuminates temporarily until the new connection is established but I have seen it remain flashing when there was a network problem.
Nice to be able to post again, after their mistake (removed by the Censorship team).
¡No Pasarán!
