OMGitsKam
Switching to Virgin, v6 connection help!
Hi i just ordered the Vip bundle, and had spoke to customer services before ordering. I don't want wire everywhere and my existing coax cable from bt is all ready running under my carpet, so for reassurance will the v6 be able to use this existing cable? Thanks
  • 8.77K
  • 452
  • 1.04K
jb66
Re: Switching to Virgin, v6 connection help!
Virgin install there own TV cable, they dont use BT wiring
  • 580
  • 50
  • 135
Corinneangela
Rising star
Virgin usually run the coax outside the house to each room you are having the V6 in so the coax doesn't run everywhere inside the house.
