  • 595
  • 45
hansi
Superfast
Message 1 of 13
Sound Issues
Anyone having sound issues with the V6 Box? I find that when i switch to different channels, I have to adjust the sound each time. Sometimes it's very loud and sometimes it's low. On recordings, I have to increase the sound quite considerably. have checked all my settings and they seem to be ok.
  • 8.02K
  • 423
  • 1.3K
Message 2 of 13
Re: Sound Issues
Do you have a surround sound setup?
It sounds as if something isn't downmixing to stereo properly.
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
  • 595
  • 45
hansi
Superfast
Message 3 of 13
Re: Sound Issues
No. Just the speakers in the TV.
  • 8.02K
  • 423
  • 1.3K
Message 4 of 13
Re: Sound Issues
What audio setting is the V6 set to, Dolby or PCM?
What TV is it, and what are the audio settings regarding down mixing a 5.1/7.1 track?
TV: XL+SkySports V6
Loc: ME10
  • 595
  • 45
hansi
Superfast
Message 5 of 13
Re: Sound Issues
Dolby and sorry don't understand the second bit.
  • 595
  • 45
hansi
Superfast
Message 6 of 13
Re: Sound Issues
Sorry it's a Sony about three years old
  • 8.02K
  • 423
  • 1.3K
Message 7 of 13
Re: Sound Issues
Try setting it to PCM.
I suspect your TV is trying to process a surround sound signal and not managing it properly.
Exactly which model? I'm expecting a setting within the TV which specifies what it does with a surround sound input when it only has 2 speakers.
TV: XL+SkySports V6
Loc: ME10
  • 595
  • 45
hansi
Superfast
Message 8 of 13
Re: Sound Issues
32EX72 and I've
changed to OCT and will check the levels again. Thanks
  • 595
  • 45
hansi
Superfast
Message 9 of 13
Re: Sound Issues
I meant PCM not OCT!
  • 353
  • 31
jonandmarkuk
Superfast
Message 10 of 13
Re: Sound Issues
Does you TV have any built in 'Volume Leveling' option in it's sound setup.
If it does turn it on, unfortunately it's common for channels to have different sound levels.
It's only recently that TV channels were told to stop making the adverts louder than the shows.
