  • 26
klynchk
Message 1 of 7
Programming the TiVo® remote control for a Samsung TV Model UE46F5500AK
I have a Samsung TV Model UE46F5500AK purchased Apr 2014 and I'd like the Tivo remote to control it well. I've not had much joy with the programming (one setting that turns off the tv but does not adjust the volume)
The documentation lists 29 codes to try
SAMSUNG
0030 0049 0050 0066 0076 0101 0102 0119 0143 0152 0154
0166 0181 0195 0209 0217 0240 0307 0318 0365 0379 0414
0421 0488 0492 0601 0624 0637 0642 0827
I'm losing heart at my abilty to find the right code - can anyone help me narrow down the search
Kevin
Helpful Answers
  • 26
klynchk
Message 3 of 7
Re: Programming the TiVo® remote control for a Samsung TV Model UE46F5500AK
jb66 wrote:
0030 is the correct code for samsung if you have a Tivo Remote
Before posting I tried the first 5 with no success.
At your suggestion I tried 0030 - it did not work. I wonder why you thought the code would work?
I did try the db method and I found one setting that turns the TV off but no channel function, no mute, no vol control
Kevin
Frizzwig
Message 4 of 7
I started from bottom of list and mine was 0642 but not same model. Hope you get yours sorted x
  • 26
klynchk
Message 5 of 7
Thanks for your suggestion - I tried a few of the numbers and then thought I'd just go with the search mode but go channel down rather than channel up.
Eventually one of the codes it sent turned off the television and I then pressed OK.
I was disappointed by the functionality I found, because all I could do was adjust volume and mute the TV.
I checked the documentation and those are the only two functions the TiVo remote controle is designed to do
Kevin
All Replies
  • 8.77K
  • 452
  • 1.04K
jb66
Message 2 of 7
  • 26
klynchk
Message 3 of 7
Kevin
Frizzwig
Message 4 of 7
  • 26
klynchk
Message 5 of 7
Kevin
  • 79
  • 19
rickwookie
Up to speed
Message 6 of 7
FWIW I did this exercise just a few days ago on a brand new Samsung TV and found the first code from that list to work was 0365. Since Samsung haven't changed their TV remote codes for a good few years now, I'm sure that code would work for your 'F' series (2013?) too.
  • 11
Magicmerly
Message 7 of 7
This is the fix for this issue for my TV not the one highlighted, thank you.
