  • 33
Thescouselander
Optical Audio Output Low Volume
Why is the volume so low out of the V6 box. I've got it set up as Dolby to PCM and the output is going optically to a 2 channel amp which is also connected to other sources.
The problem is the V6 box seems volume seems lower than the other sources which means I have to turn the amp up quite far and then if I forget to turn it down again I get my ears blasted out when listening to another source.
Any ideas how I can fix this?
  • 21.5K
  • 804
  • 1.59K
Re: Optical Audio Output Low Volume
Hi Thescouselander,
Thanks for your post Smiley Happy
Apologies to hear you are having an issue with the volume when connecting through your amp.
When connecting the V6 box directly to the TV and using the volume that way, do you get the same low output?
Keep me posted.
Kath_F
Merry Christmas & a Happy New Year
