  • 40
halcyondays
Message 1 of 17
Netflix error 312 on V6 and not using SH2 in Modem Mode
Hi all
I know there are many threads on this issue but was wondering if anyone had a solution for my problem as i am not using another router and the SH2 is not in modem mode.
I've reset the router and even tried going into modem mode and then trying to check the DNS settings but i cannot get into the settings using the ip given.
I've reset the V6  too and still getting the same issues.
Any help would be much appreciated
Ant
  • 69
  • 8
Nialli
Dialled in
Message 2 of 17
Re: Netflix error 312 on V6 and not using SH2 in Modem Mode
I think this is a pretty serious bug and VM need to address it. I tried all the workaround suggestions in the main thread on this topic http://community.virginmedia.com/t5/Virgin-TV-V6/V6-Netflix-App-not-working/td-p/3311148 and still have no Netflix on my Wi-Fi connected V6.
  • 40
halcyondays
Message 3 of 17
cheers for the reply mate.
I can't find anywhere that mentions this issue on superhubs that are not being used in modem mode.
I also think it's stopping me from setting up the away from home streaming.
I can stream channels but not recordings.
I posted on your blog too.
  • 22.41K
  • 850
  • 1.65K
Message 4 of 17
Hi halcyondays,
Thanks for your post and apologies to hear about the issues you are having trying to watch Netflix via your V6 box.
In order to help you with this I will need some information from you. I have sent you a private message regarding this and will investigate further once I receive your reply.
Just click on the little plum envelope at the top right hand side of the page to access your inbox.
Speak soon,
Kath_F
  • 22.41K
  • 850
  • 1.65K
Message 5 of 17
Re: Netflix error 312 and not using SH2 in Modem Mode
Hi halcyondays,
Thanks for coming back to me with your information.
I have made the change for you now so if you can reboot your hub and V6 box and then try Netflix again, how do things look?
Come back and let me know.
Kath_F
  • 69
  • 8
Nialli
Dialled in
Message 6 of 17
Kath - if that works for him, can you please do similar for me?
Nialli
  • 40
halcyondays
Message 7 of 17
I'm just testing mate, will post if it works. But....you will get blocked from dodgy sites from what i can tel haha
  • 40
halcyondays
Message 8 of 17
Ok,,,,,so that works which is great but i'm really not happy i have to activate websafe just to get it to work.
  • 40
halcyondays
Message 9 of 17
Just turned off the child safe setting to see if Netflix still worked and it does. So just having the Virus setting on does still allow Netflix to work
  • 69
  • 8
Nialli
Dialled in
Message 10 of 17
That's interesting. I don't have Web Safe (no kids in this house) and don't use a PC. Any idea why Kath's fix worked?
