  • 180
  • 14
lempsky
Superfast
Message 1 of 9
Front Panel Lights
Just watched advert on tv V6 seems there,s more lights on front panel than my one white light,any one else notice this and have the answer. How do we no how many and if its doing your recordings.
  • 8.02K
  • 423
  • 1.3K
Message 2 of 9
Re: Front Panel Lights
With 6 tuners, you know it's recording most likely because you set it to record.
For any more detail, use the Info button on the remote and scroll down to see which tuners are being used for what.
TV: XL+SkySports V6
BB: 200Mbps SuperHub: Arris
Loc: ME10
    Please use the Search feature before starting a new thread
To thank or if you Like a post, use the Kudos +button. If it's an answer to your query, click Options.
Finally, if all else fails, take a deep breath and remember there's more to life than the internet and TV!
  • 180
  • 14
lempsky
Superfast
Message 3 of 9
Mm bit sarcastic for me that me old m8, watch advert and get back to me i know the info button route.
  • 8.02K
  • 423
  • 1.3K
Message 4 of 9
Happy to if you can tell me where - I've not seen an advert for years!
TV: XL+SkySports V6
Loc: ME10
  • 180
  • 14
lempsky
Superfast
Message 5 of 9
Why did you respond to my post then, when my main qstn reffered to the front panel lights on the advert and you have,nt watched an advert for years.
  • 8.02K
  • 423
  • 1.3K
Message 6 of 9
If you're asserting that there are additional lights on the box in the advert, and there aren't on the delivered box (as has already been discussed at length on here somewhere), then the advert isn't representative of the product.
The only way to see if the V6 is recording is to use the On Screen Display.
TV: XL+SkySports V6
Loc: ME10
  • 10.3K
  • 917
  • 2.09K
Message 7 of 9
@PrinterElf was simply wishing to view the advert and see if he could confirm what you are claiming.
However, we all know the box only has one large LED.
  • 17.29K
  • 1.57K
  • 2.96K
Message 8 of 9
There is one other LED that shows up next to the Virgin Media logo when there are connectivity problems, but I wouldn't expect to see that on an advert anywhere!
  • 180
  • 14
lempsky
Superfast
Message 9 of 9
Listen think we drop it now getting ridiculous, we will put it down to my eye sight and move on,thanks..i think.
